How to calculate power efficiency with Infineon Designer?
IFX_Publisher4
50 questions asked First comment on KBA First reply posted
Follow the below steps while calculating the power efficiency with Infineon Designer. For example, while using BSZ084N08NS5 and other devices.
1.    Open the circuit and login with myInfineon account: https://www.infineon.com/
2.    Check & set the power types of components
3.    Set transient analysis, enable power dissipation analysis, and run simulation using Analysis -> Transient
Contributors
