Knowledge Base Articles
How to adjust output current according to LED temperature and binning of a DC-DC LED driver?
MohammedA_41
Our LITIX boost controllers like TLD5099EP have two options to dim the output current without a microcontroller:
  • Analog current adjustment
  • Embedded PWM engine
In the system these two options can be used to:
  • adjust the output current as a function of binning resistor
  • thermal foldback (thermal protection)
The two functions are activated by analog voltages at the pins SET  and PWMI - e.g. by resistor dividers. Then are no interferences between these two functions.
See the datasheets at our LITIX pages
Version history
Revision #:
1 of 1
Last update:
‎Nov 25, 2021 01:53 AM
Updated by:
Contributors
