How to Monitor MBR3 CapSense Signal Through I2C – KBA225809
Community-Team
50 questions asked 10 questions asked 5 questions asked
Author: RyanZ_36          Version: **
Translation - Japanese: I2Cを介してMBR3 CapSense信号を監視する方法– KBA225809- Community Translated (JA)
Question:
How can I monitor MBR3 CapSense® raw count, baseline, and diff count?
Answer:
Unlike with CapSense in PSoC® 4, firmware of MBR3 devices and its I2C register map are fixed. In this case, if you want to read the MBR3 CapSense raw count, baseline, and diff count, you should know how to operate MBR3 registers. MBR3 registers details are documented in MBR3 registers map.
To read MBR3 CapSense raw count, baseline and diff count, use the following registers:
Register Name
Register Address
Register description
SENSOR_ID
0x82
Read and write. The ID of the sensor for which to report the sensor debug data.
Valid values of this register depend on the number of sensors in the part; valid values for a part are 0 to (number of sensors - 1). Sensor ID is the sensor index ID described in the MBR3 datasheet. For example, Sensor ID of CS0 is 0, Sensor ID of CS9 is 9.
DEBUG_SENSOR_ID
0xdc
Read only. This register takes its value from the SENSOR_ID register.
DEBUG_DIFFERENCE_COUNT0
0xde
Debug difference count for the sensor specified in SENSOR_ID.
DEBUG_BASELINE0
0xe0
Debug baseline count for the sensor specified in SENSOR_ID.
DEBUG_RAW_COUNT0
0xe2
Debug raw count for the sensor specified in SENSOR_ID.
DEBUG_AVG_RAW_COUNT0
0xe4
Average filtered raw count of the debug proximity sensor with the advanced low-pass filter applied for the sensor specified in SENSOR_ID. If the advanced low-pass filter is disabled or the sensor number in SENSOR_ID corresponds to any sensor other than a proximity sensor or a disabled sensor, this value is undefined.
Take Bridge Control Panel as I2C master as an example. To read MBR3 CS6 (should have been enabled) raw count, diff count, and baseline, the command line can be:
“W 37 82 06 P ;Specify Sensor ID
“W 37 DC P ;Specify the register start to read
“R 37 DC X X X X X X X X P ; Read debug sensor ID, diff count, baseline and raw count
Where “W” “R” or “P” is write, read or stop command, “37” is MBR3 I2C slave address, “82” is SENSOR_ID register address in hex, “06” is Sensor ID of CS6, “DC” is the DEBUG_SENSOR_ID register address. “X X X X X X X X” is the byte number to read.
Visit community.cypress.com or contact Cypress tech support for more details.
Reference:
CapSense MBR3
CY8CMBR3xxx CapSense Express Controllers Registers TRM
Contributors
