How to Enable Expression View
Aardvark
10 questions asked 5 questions asked First reply posted
  • Expression View is the advanced feature in PSoC Creator which enable users to configure user module finely.
  • To use the Expression View, user needs to follow below instruction.
  • From Tools tab, select Option.
Figure1. Tools
  • Click Options… and expand Design Entry. Select Component Catalog.
Figure2. Option memu
  • Check Enable Param Edit Views. Click Apply Button and Close the window.
  • Open the user module to be configured (example, CapSense).
  • Right click on the tab which includes items to be configure. Pop up shows Show Custom View and Show Expression View. By clicking Show Expression View, user can configure user module parameters more finely.
Figure3. Custom View and Expression View Selection
Figure4. Expression View in CapSense
  • To revert the mode, right click on the tab again, then select Show Custom View (Refer Figure.3).
Contributors
