How to Check E_ERR/P_ERR Status Errors in the Linux MTD SPI Driver – KBA220225
- Mark as Read
- Printer Friendly Page
Version: **
Translation - Japanese: Linux MTD SPIドライバでE_ERR/P_ERRステータス エラーを確認する方法– KBA220225- Community Translated (JA)
Question:
How do I add flash program/erase failure status checking to the Linux SPI MTD SPI Driver?
Answer:
The Linux master code doesn’t check for program/erase failure of SPI driver. The following steps will add this error-checking feature to the driver
1. Add E_ERR and P_ERR bit field definitions to SPI driver for FL-S and FS-S (in case of FL-L, use Status Register 2 instead of Status Register 1):
- Open include/linux/mtd/spi-nor.h
- Find Status Register bits definitions and replace the following:
#define SR_TB BIT(5) /* Top/Bottom protect */
with:
#define SR_E_ERR BIT(5) /* Erase error occurred */
#define SR_P_ERR BIT(6) /* Programming error occurred */
- Find Flash opcodes section and add Clear Status Register opcode
#define SPINOR_OP_CLSR 0x30 /* Clear status register */
2. Add E_ERR and P_ERR status bit checking to the Status Ready checking subroutine:
- Open drivers/mtd/spi-nor/spi-nor.c
- Add clear_sr() subroutine
* Returns negative if error occurred.
static inline int clear_sr(struct spi_nor *nor)
return nor->write_reg(nor, SPINOR_OP_CLSR, NULL, 0);
- Add a user notification subroutine when erase or program failure happens, for example, user_error_handler()
- Find static inline int spi_nor_sr_ready(struct spi_nor *nor)
- Modify the code from:
int sr = read_sr(nor);
if (sr < 0)
return sr;
else
return !(sr & SR_WIP);
to:
if (sr < 0)
return sr;
else if ((sr & SR_E_ERR) || (sr & SR_P_ERR))
user_error_handler();
write_enable(nor);
clear_sr(nor);
- cypress
- e_err
- fl-l
- fl-s
- fs-s
- linux
- mtd
- p_err
- s25fl127s
- s25fl128l
- s25fl128s
- s25fl256l
- s25fl256s
- s25fl512s
- s25fs064s
- s25fs128s
- s25fs256s
- s25fs512s
- s70fl01gs
- s70fs01gs
- spansion
- spi
- write
