How the magnetoresistive sensor detects four-pole rotor position
Infineon_Team
The Infineon angle sensor has nothing to do with the number of magnetic pole pairs of the rotor. The Infineon angle sensor detects the magnetic field direction of magnetic steel embedded in the shaft end.
