How good is GPS with Infineon's products?
Infineon_Team
The new dual-band GPS/GNSS technology provides significantly improved location tracking with a new, outstanding 30-cm range accuracy, enabled by ultra-low-noise RF amplifiers with high linearity and enhanced receiver sensitivity.
Developed in Infineon's advanced SiGe process, the BGA123N6 and BGA125N6 low-noise amplifiers provide best-in-class noise figures and linearity for maximum signal reception while preserving valuable battery power.
By choosing from the wide supply voltage range of single-band and dual-band LNAs, designers enjoy high flexibility and integration to achieve high-density, compact designs.
