How an open-load condition can be detected by PROFET™ +2 12V devices?
Infineon_Team
Open-loads in PROFET™ +2 12V devices can be detected by using the integrated diagnosis feature and external components.
For some loads, it may be necessary to check their availability without powering them up. For example, it may be necessary to check if loads, bulbs or LEDs (or the cable they are connected to) are intact or broken, without creating a flash light by switching them on.
Examples of the open load detection at "OFF" for a single output and for multiple device or outputs are shown in Figure 1 and Figure 2.
Note:              These are very simplified examples of an application circuit. The function must be verified in the real application.
Figure 1       Application diagram with open load detection circuitry
Figure 2       Application diagram with open load detection circuitry for multiple outputs and devices
In the example circuitry in Figure 1, a small current (few milliamperes) is injected into the output, powerful enough to pull up the output if there is no load connected, but not powerful enough to activate the load in a disturbing manner. If DEN = "high" while IN = "low" and the output voltage of a PROFET™ +2 12V increases close to VS, drain-source voltage will be lower than VDS(OLOFF) and the PROFET™ +2 12V will provide an open load signal IIS(OLOFF). To avoid continuous power losses in "OFF" state in open-load condition, and to be able to distinguish open load from short-to-battery in "off" state, the pull-up circuitry must be switchable.
The value of the output voltage depending on different conditions can be seen in Table 1.
Table 1: VDS voltage with fixed pull-down and switchable pull-up
Channel OFF
Load OK
Open-load
Short circuit to battery
Pull-Up activated
VDS ~ VS
VDS ~ 0V
VDS ~ 0V
Pull-Up deactivated
VDS ~ VS
VDS ~ VS
VDS ~ 0V
Figure 3 shows a possible software strategy using the circuitries in Figure 1 and Figure 2.
Figure 3       Example code for open-load or short-to-battery detection
The limits of the pull-up currents have to be below the maximum allowed load current, which does not activate the load. That depends strongly on the load, and has to be adapted accordingly. To compensate leakage currents from battery to output (e.g. output leakage current IL(OFF)) and from output to GND, pull-up and pull-down resistors might be needed.
More information
Application note: https://www.infineon.com/dgdl/Infineon-Z8F65048819_PROFET_2_FAQ-ApplicationNotes-v01_20-EN.pdf?fileI...
Ask the Smart Power Switches Community
Infineon Developer Community is available 24x7 for you to connect and network with engineers across the globe. Get help from Infineon support engineers, and expert members to solve your design challenges anytime, from anywhere, in any topic, and in your preferred language.
Infineon Smart Power Switches & Gate Driver Toll Suite
To address the new needs in automotive power distribution, Infineon offers a wide variety of products and in addition this Smart Power Switches & Gate Driver Tool Suite to simplify the design in process.
Infineon Smart Power Switches & Gate Driver Tool Suite supports system architects and hardware designers from the idea to the realization.
