Hardware reset parameters of SEMPER™ NOR Flash memory - KBA238604
Infineon_Team
This KBA describes the reset timing of SEMPER™ NOR Flash memory devices, including the 3-V S25/26/28HL-T and 1.8-volt S25/26/28HS-T families.
When the RESET# signal is driven LOW for at least the Reset Pulse Width time, the device begins the hardware reset process. This process continues for the duration of the Reset Pulse Hold time. The hardware reset causes the same initialization process that is performed at power-up and requires Power Up time.
Following the end of Reset Pulse Hold time or the Reset Hold time following Reset Pulse Width time, the device transitions to the Interface STANDBY state and can accept commands. This means that a certain period of Reset Pulse Hold time is required for the hardware reset process to complete, and the sum of Reset Pulse Width time and Reset Hold time must be greater than the minimum required Reset Pulse Hold time (Figure 1). If the time to complete the power-up sequence is equal to or longer than Power Up time or Reset Pulse Hold time, the initial Reset Hold time or Reset Setup time may not be required (Figure 2).
Connecting the above timing descriptions to the symbols in the SEMPER™ datasheet, we get the values listed in Table 1. Note that the Reset Pulse Hold time for HL and HS family SEMPER™ devices is significantly longer compared to the previous generations of Infineon flash memory.
Table 1 Hardware Reset parameters
Timing
Symbol
Parameter
Min
Typ
Max
Unit
tRP
RESET# pulse width
200
ns
tRH
Reset pulse hold - RESET# low to CS# low
(HL256T / HS256T)
(HL512T / HS512T)
(HL01GT / HS01GT)
(HL02GT / HS02GT)
550 / 600
450 / 500
500 / 500
450 / 500
µs
Reset Setup time
tRS
Reset setup - RESET# high before CS# low
50
ns
Reset Hold time
Power Up time
tPU
VCC(min) to read operation
(HL256T / HS256T)
(HL512T / HS512T)
(HL01GT / HS01GT)
(HL02GT / HS02GT)
550 / 600
450 / 500
500 / 500
450 / 500
µs
Figure 1 Hardware reset using RESET# input
Figure 2  Power-On Reset followed by hardware reset
Contributors
