Handling “Port4 to Port7” GPIO Interrupt in PSoC 4 Series – KBA231049
- Mark as Read
- Printer Friendly Page
Author: LinglingG_46 Version: **
Translation - Japanese: PSoC 4シリーズでの「Port4 から Port7」のGPIO割り込みの処理 – KBA231049 - Community Translated (JA)
Question:
How do I handle the “Port4 to Port7” GPIO interrupt?
Answer:
In PSoC® 4 series, GPIO dedicated interrupt only supports Port 0, Port1, Port2, and Port3, as listed in Table 1.
Table 1. List of PSoC 4 Interrupt Sources
Interrupt | Arm® Cortex®-M0+ Exception No. | Interrupt Source |
NMI | 2 | SYSCALL_REQ |
IRQ0 | 16 | GPIO Interrupt – Port 0 |
IRQ1 | 17 | GPIO Interrupt – Port 1 |
IRQ2 | 18 | GPIO Interrupt – Port 2 |
IRQ3 | 19 | GPIO Interrupt – Port 3 |
IRQ4 | 20 | GPIO Interrupt – All Port |
If you want to use GPIO interrupt in Port4 to Port7, it needs to handle the interrupt source “GPIO Interrupt - All Port”.
Here are the design and implementation steps to handle GPIO Interrupt - All Port:
- Drag a Global Signal component, choose Combined port interrupt (AllPortInt).
- Drag a digital input pin, assign to any pin in Port4 to Port7.
- Enable the input interrupt. Choose one of the three modes: falling edge, rising edge, or both edges, as required.
- In the main function, start the Global Signal component isr.
- Define an interrupt handler to process the interrupt.
Here is the code snippet:
#include "project.h"
static void AllPort_Interrupt_Handle(void)
Pin_isr_ClearInterrupt();
CyGlobalIntEnable; /* Enable global interrupts. */
isr_2_StartEx(AllPort_Interrupt_Handle);
/* Place your initialization/startup code here (e.g. MyInst_Start()) */
for(;;)
/* Place your application code here. */
/* [] END OF FILE */
- gpio interrupt
- psoc
