Handling CYU3P_USBEP_SS_RESET_EVT event in FX3 - KBA226725
- Mark as Read
- Printer Friendly Page
Community Translation: FX3のCYU3P_USBEP_SS_RESET_EVTイベントを処理する – KBA226725
Version: **
This document describes how to handle the CYU3P_USBEP_SS_RESET_EVT in EZ-USB™ FX3 firmware.
This event can occur only for an IN endpoint when many USB 3 protocol-level retries occur on the bus due to a bad cable or bad testing/running environment (where there can be protocol-level CRC errors).
Do the following to handle the event:
Step 1:
Register the endpoint event callback in the firmware to check if this event is triggered. Use the CyU3PUsbRegisterEpEvtCallback()API to register the endpoint callback.
Usage:
CyU3PUsbRegisterEpEvtCallback (CyU3PUsbEpEvtCb_t cbFunc, uint32_t eventMask, uint16_t outEpMask, uint16_t inEpMask);
cbFunc : Callback function pointer
eventMask: The enumeration of different endpoint events are as follows:
To generate the callback for CYU3P_USBEP_SS_RESET_EVT, set the eventMask as 0x0100. To generate the callback for both CYU3P_USBEP_SS_RESET_EVT and CYU3P_USBEP_SS_RETRY_EVT, set the eventMask as 0x0110.
outEpMask: Bitmap variable representing the OUT endpoints whose events are to be enabled. Bit 1 represents EP 1-OUT, 2 represents EP 2-OUT, and so on.
inEpMask: Bitmap variable representing the IN endpoints whose events are to be enabled. Bit 1 represents EP 1-IN, 2 represents EP 2-IN, and so on.
Note: See the example in the following path of the FX3 SDK where this callback is registered and the event is handled for two IN Endpoints:
[FX3_Installation_Path]\EZ-USB FX3 SDK\1.3\firmware\basic_examples\cyfxgpiftousb
Step 2:
This event is endpoint-specific. When this event occurs for an endpoint, the specific IN endpoint must be stalled. See the following code snippet:
if (evtype == CYU3P_USBEP_SS_RESET_EVT)
if (epNum == CY_FX_EP_CONSUMER)
CyU3PDebugPrint (2, "Halting USB Streaming EP: %d\r\n", BulkRstCnt++);
CyU3PUsbStall (CY_FX_EP_CONSUMER, CyTrue, CyFalse);
if (epNum == CY_FX_EP_LOOP_IN)
CyU3PDebugPrint (2, "Halting USB Loopback EP: %d\r\n", LoopRstCnt++);
CyU3PUsbStall (CY_FX_EP_LOOP_IN, CyTrue, CyFalse);
Step 3:
When the IN endpoint is stalled, the API in the host application that requests the data on this endpoint fails; the error code indicates Endpoint Stall.
In that case, the host application should send a CLEAR_FEATURE request targeting this specific IN endpoint (for which the data request failed).
When CLEAR_FEATURE is received, the FX3 firmware should have the following handler:
if ((bTarget == CY_U3P_USB_TARGET_ENDPT) && (bRequest == CY_U3P_USB_SC_CLEAR_FEATURE)
&& (wValue == CY_U3P_USBX_FS_EP_HALT))
if (glIsApplnActive)
if (wIndex == CY_FX_EP_CONSUMER)
CyU3PUsbSetEpNak (CY_FX_EP_CONSUMER, CyTrue);
CyU3PBusyWait (125);
CyU3PDmaChannelReset (&glDmaChHandle);
CyU3PUsbFlushEp(CY_FX_EP_CONSUMER);
CyU3PUsbResetEp (CY_FX_EP_CONSUMER);
CyU3PDmaChannelSetXfer (&glDmaChHandle, CY_FX_GPIFTOUSB_DMA_TX_SIZE);
CyU3PUsbStall (wIndex, CyFalse, CyTrue);
CyU3PUsbSetEpNak (CY_FX_EP_CONSUMER, CyFalse);
isHandled = CyTrue;
CyU3PUsbAckSetup ();
Both these code snippets are implemented in the gpiftousb example ([FX3_Installation_Path]\EZ-USB FX3 SDK\1.3\firmware\basic_examples\cyfxgpiftousb)
Note: See also Section 2.3.IV of the FX3 SDK troubleshooting guide in addition to this article:
[FX3_Installation_Path]\EZ-USB FX3 SDK\1.3\doc\firmware\ FX3_SDK_TroubleShooting_Guide.pdf
- FX3-FX3S
