Glitch while Changing P or Q of CY22393
06:58 PM
- Mark as Read
- Printer Friendly Page
Sep 26, 2009
06:58 PM
Question: Why is switching to other output frequencies not glitch-free when P or Q values are changed?
Answer:
The reason for switching the clock outputs off or changing the source to the reference is because the serial programming bits take effect right after the acknowledge pulse is sent. Since the P and Q values are stretched out over 3 bytes, the PLL could go into an illegal state and output an unusable signal during I2C shifting. There is a possibility of glitching when switching the output off or changing it to the reference.
- clock generation
Rate this article:
Contributors
This widget could not be displayed.Anonymous
