Getting Started with Infineon USB Type-C Products
- Mark as Read
- Printer Friendly Page
How to develop a design with Infineon USB Type-C products?
Infineon offers eight USB Type-C port controllers:
- EZ-PD™ CMG1
- EZ-PD CCG6
- EZ-PD CCG5
- EZ-PD CCG4
- EZ-PD CCG3PA
- EZ-PD CCG3
- EZ-PD CCG2
- EZ-PD CCG1
CMG1, CCG6, CCG5, CC3PA, CCG4, and CCG3 port controllers are fully compliant with the latest USB-IF defined USB Type-C Revision 1.3 and USB Power Delivery Revision 3.0 (PD3.0) specifications.
CCG2 and CCG1 controllers comply with older USB Type-C Revision 1.2 and Power Delivery Revision 2.0 (PD2.0) specifications.
Information on the Infineon USB Type-C products can be found on the USB Type-C and Power Delivery products webpage.
USB Type-C Product design
Follow these steps to get started with the design:
- Watch the training video available here, to get more information on Type-C technology and its applications
- See the datasheets of CCGx/CMGx for more details.
- Start prototyping your design using one of the CCGx Kits offered by Infineon.
CCGx Kit |
Type-C Controller |
Application(s) Supported |
CCG3 |
Single Port Downstream Facing Port (Host) application with Dual Role Power, DisplayPort source, and USB host |
CCG4 |
Single or Dual Port Downstream Facing Port (Host) application on a single chip with Dual Role Power, DisplayPort source, and USB host. |
CCG3PA |
USB Type-C Power Adapter, USB Type-C Mobile Charger and USB Type-C Power Bank applications with Dual Role Power |
4. Start your firmware configuration and customization using the EZ-PD™ Configuration Utility and the CCGx Software Development Kits (SDK) offered by Infineon.
Firmware Customization Tool |
Supported Port Controllers |
CCG3, CCG4, CCG4M, CCG5 |
CCG3PA |
CMG1, CCG6, CCG5, CCG3PA, CCG4, CCG3, CCG2 CCG1 |
5. See the following Getting Started with CCGX application notes to kick start your design with EZ-PD CCGx:
6. See the following hardware design best practices application notes to kick start schematic design and layout guidelines:
7. EZ-PD CCG1 and EZ-PD CCG2 port controllers are USB PD2.0 controllers which do not support the newer USB PD3.0 specifications. Infineon provides limited support for CCG1 and CCG2 controllers, and does not recommend their use in new designs.
a. CCG1 and CCG2 Kits
CCGx Kit |
Type-C Controller |
CCG1 |
Single Port Downstream Facing Port (Host) application with Dual Role Power, DisplayPort source, and USB host. Single Port Upstream Facing Port (Device) with Dual Role Power, DisplayPort sink, and USB device |
CCG2 |
E-Marker Cable |
CCG2 |
b. CCG2 SDK
SDK Name |
Product Name |
EZ PD Software Development Kit (Version 3.2.1 and older only) |
CCG2 |
c. Application Notes: Hardware Design Guidelines for EZ-PD™ CCG2
Infineon has developed numerous Type-C reference designs using CCGx to help reduce your design cycle time, effort and risk. Each reference design has been built and tested. The following table gives links to various reference designs and applications notes, which can help you to start the design with EZ PD CCGx and CMGx.
Applications |
CCG1 |
CCG2 |
CCG3 |
CCG4 |
CCG3PA |
CMG1 |
Electronically Marked Cable Assembly (EMCA) |
Type-C to Legacy USB |
Type-C to DisplayPort |
Type-C to HDMI/VGA/DVI |
Monitor/Dock |
Charge-Through Dongle |
18W Power Adapter |
20W Power Adapter |
24W Power Adapter |
Car Charger |
Power Bank |
Coming Soon (Southchip 18W) Coming Soon (Southchip 45W) |
QC4.0 Cell Phone chargers 27W |
Notebook Adapter 45W |
Available (MPS) |
HDMI over USB-C Alternate Mode |
For further information, visit the Infineon Developer Community or submit a case in the Online Tech Support Case System.
Version: *A
Translation - Japanese: Infineon USB Type-C 製品入門 - KBA204071 - Community Translated (JA)
- application note
- CC3PA
- ccg
- ccg3
- ccg4
- ccg5
- ccg6
- cmg1
- cy4501
- cy4502
- cy4531
- cy4532
- cy4541
- ez-pd ccg1
- ez-pd ccg2
- ez-pd ccg3
- ez-pd ccg3pa
- ez-pd ccg4
- ez-pd ccg5
- ez-pd ccg6
- ez-pd cmg1
- ez-pda ccg1 type-c port controller
- ez-pda ccg2 type-c cable controller
- ez-pda ccg3 type-c port controller
- EZ-PD™ CMG1
- reference design
- technical reference manual
- usb type-c
