Footprint / Landpattern of an SRAM?
Translation - Japanese: SRAMのフットプリントとランドパターンについて。- Community Translated (JA)
Question: Where can i get recommended footprint / Landpattern for standard packages?
Answer:
The footprint sram parts can be found at ipc.org. Please click on the following link: http://ipc.org/default.aspx You would have to register to get to the calculator. Once you register in the dropbox you will be given an option to enter your choice of package and there you can find the landpattern.
Contributors
