Flushing the SX2 Read/Write FIFO
12:00 AM
- Mark as Read
- Printer Friendly Page
Dec 19, 2008
12:00 AM
Question: Should the SX2 FIFO be flushed before read/write?
Answer:
As part of an endpoint initialization or reset, the endpoint FIFO should be cleared (flushed). This is done by sending the INPKTENDFLUSH command with the appropriate endpoint identifier upper bits specified. Sending an INPKTEND with 0xF0 data will flush all FIFOs.
Rate this article:
Contributors
This widget could not be displayed.Anonymous
