FMCW radar working principle simulation based on python — Chapter 2:Velocity simulation
- Mark as Read
- Printer Friendly Page
This article will introduce how to use python to implement the simulation of FMCW working principle, the second chapter content will introduce the principle of velocity detection.
FMCW radar working principle simulation based on python — Chapter 1:Distance simulation
Part 1: Principle of velocity detection
As talked in the end of chapter 1, small scale movement is hard to be detected by range-frequency relationship, as shown in the picture below, no obvious shifting can be found in the Spectrum during the frame period. Besides, if there several targets with the same distance, we cannot distinguish them by the range-frequency relationship because they have the same IF frequency in the Spectrum.
However, we can detect these small scale movements and distinguish different targets by measuring the phase change of IF signals. The basic idea of velocity estimation by phase changing is shown below:
Part 2: 1D speed estimation
Step_1: Speed Dimension Data Extraction
Extract one sampling point per chirp, for a frame with 128 chirp, there will be a list of 128 points.
chirpamp = []
chirpnum = 1
while(chirpnum<=Nd):
strat = (chirpnum-1)*1024
end = chirpnum*1024
chirpamp.append(IFx[(chirpnum-1)*1024])
chirpnum = chirpnum + 1
Step_2: Speed Dimension FFT for Phase difference and Velocity
doppler = 10*np.log10(np.abs(np.fft.fft(chirpamp)))
FFTfrequency = np.fft.fftfreq(Nd,1/Fs)
velocity = 5*np.arange(0,Nd)/3
Part 3: 2D FFT and Velocity-Distance Relationship
Z_fft2 = abs(np.fft.fft2(mat2D))
Data_fft2 = Z_fft2[0:64,0:512]
Source code of this chapter:
#Range Spectogram
plt.subplot(4,2,6)
plt.specgram(IFx,1024,Fs)
plt.xlabel('Time')
plt.ylabel('Frequency')
plt.title('Range-Frequency Spectogram')
plt.show()
#Speed Calculate
#速度维数据提取
chirpamp = []
chirpnum = 1
end = chirpnum*1024
#速度维做FFT得到相位差
#plt.subplot(4,2,7)
plt.plot(velocity[0:int(Nd/2)],doppler[0:int(Nd/2)])
plt.xlabel('Velocity')
plt.ylabel('Amplitude')
plt.title('IF Velocity FFT')
plt.show()
#2D plot
mat2D = np.zeros((Nd, Nr))
i = 0
while(i<Nd):
mat2D[i, :] = IFx[i*1024:(i+1)*1024]
i = i + 1
#plt.matshow(mat2D)
#plt.title('Original data')
#plt.subplot(4,2,8)
plt.imshow(Data_fft2)
plt.xlabel("Range")
plt.ylabel("Velocity")
plt.title('Velocity-Range 2D FFT')
plt.tight_layout(pad=3, w_pad=0.05, h_pad=0.05)
plt.show()
