Estimation method of internal pull-up/pull-down resistance
KatsumasaH_16
10 solutions authored First comment on KBA 50 sign-ins
Original KBA:  内部プルアップ・プルダウン抵抗値の見積もり方法
Estimate the resistance values of the pins of pull-up / pull-down resistors inside the device to help the user consider whether a separate external pull-up / pull-down resistor needs to be fitted.
         Check the guaranteed operating range of VCC in the data sheet.
·         Next, check the DC characteristics of the pin leaks (ILI, ILO).
·         Calculate the resistance value based on the relationship of Resistance = Voltage / Current.
Example:
VCC = 3.3 V, ILI/ILO = 2.0 uA
Internal resistance = 3.3V / 2.0uA = 1.65 Mohm
