Error using XMC™ Flasher tool to program Demo Position2Go kit
Infineon_Team
The warning errors occur when both USB ports of the board are not connected to their respective cables simultaneously. Connecting 2 x USB cables on both ports will eliminate this error. Kindly revert if the error persists.
