EZ-USB™ Suite not opening on macOS versions – KBA236182
10:40 PM
- Mark as Read
- Printer Friendly Page
Sep 29, 2022
10:40 PM
Version: **
Do the following to resolve the error when EZ-USB™ Suite quits unexpectedly in macOS:
- Navigate to FX3_SDK_1.3.4_MacOS/eclipse/ezUsbSuite.app/Contents/MacOS and run the following command in the terminal:
./ezUsbSuite
- Determine the missing library from the error message in the terminal. In this case, the error is due to the missing jdk1.8.0_281 libserver.dylib library.
- Install jdk1.8.0_281 (or the same version as indicated in the error message).
- Open terminal and Navigate to /Library/Java/JavaVirtualMachines/jdk<version>/Contents/Home/lib and create a soft link for the missing library by using the following command:
sudo ln -s ../jre/lib/server/libjvm.dylib libserver.dylib - Run the application. See the following document for more information:
FX3_SDK_1.3.4_MacOS\cyfx3sdk\FX3_SDK_MacOs_Support.pdf
Labels
Rate this article:
