Knowledge Base Articles
EZ-USB™ SX3 HDMI 4K Capture Card Solution Demo Kit - KBA233573
Chelladurai
Author: Mitilesh                                           Version: **
The EZ-USB™ SX3 HDMI 4K Capture Card is a USB Video Class (UVC), USB Audio Class (UAC) compliant capture card which is ideally suited for capturing video and audio from any HDMI source and supports up to 4K, 30fps/ 1080p, 60fps in YUV format video. It is based on Infineon® EZ-USB™ SX3, a USB3.1 peripheral controller, Lattice ECP5 FPGA and HDMI receiver IC.
Figure 1. SX3 HDMI RX 4K capture card block diagram
Any HDMI source such as Laptop, Raspberry Pi, Gaming consoles, Android TV set-top box, media streaming devices like Amazon fire TV, Apple TV, and so on can be used with this kit. The “Microsoft Camera” application, e-CAMView, MPC-HC player or any UVC player application can be used to view this video on a USB Host. This is a form factor kit of size 26-mm × 75-mm.
The kit schematic, BOM, and board files are attached with this document. You can build customized board using these files.
The kit firmware configuration file includes the SX3 configuration and FPGA bit file which are attached with this document.
Figure 2. EZ-USB™ SX3 HDMI 4K capture card - Rev 01
Figure 3. Type-C and HDMI receptacles of EZ-USB™ SX3 HDMI 4K capture card – Rev 01
Follow the below steps to capture the 4K video from HDMI source using EZ-USB™ SX3 HDMI 4K Capture Card:
  1. Download and install EZ-USB SX3 Configuration Utility.
  2. Connect the EZ-USB™ SX3 HDMI 4K Capture Card Solution Demo Kit to USB 3 port of PC using a USB-C-to-A cable or a USB-C-to-C cable.
  3. Download the SX3 Configuration file (sx3_hdmi_4K_capture_card.zip) for EZ-USB™ SX3 HDMI 4K Capture Card from the attachment.
  4. Import the sx3_hdmi_4K_capture_card.zip file into SX3 Configuration Utility using the Import Configuration option.
    Figure 4. Import configuration option in SX3 configuration utility
  5. Select USB boot mode using the boot mode selection switch (available on Rev 02 board).
  6. Program the configuration to the connected kit.
    Figure 5. Program configuration option in SX3 configuration utility
  7. Once the firmware and configuration files are loaded, select SPI boot mode using the boot mode selection switch (implemented on Rev 02 board).
  8. Disconnect and re-connect the USB cable.
  9. In Windows Device Manager, the kit will be visible as SX3 in the Cameras and Audio Inputs and Outputs section.
    Figure 6. SX3 devices in Device Manager after Enumeration
  10. Connect any HDMI source to the HDMI port of the kit using the supplied HDMI cable. The HDMI source will stream video and audio. The kit will capture the same and send it over the USB port to PC.
  11. To view the video from HDMI source, run the Windows Camera application and choose SX3 in the Devices option. The video from the HDMI kit will be captured on PC screen.
    Figure 7. Video played on HDMI source viewed in Windows camera application
  12. To listen the audio from HDMI source, perform these steps:
    1. Open the Windows Control Panel.
    2. Click the Hardware and Sound icon.
    3. Click the Sound icon.
    4. Click the Recording tab.
    5. Double click on Digital Audio Interface- SX3.
    6. Click the Listen tab in the Digital Audio Interface Properties dialog box.
    7. Select the Listen to this device checkbox and click the Apply button. You should hear the audio from HDMI in Laptop speakers.
    8. Adjust your speaker volume.
Figure 8. Testing the audio from HDMI source
Figure 9. Enable “Listen to this device” option to route audio from HDMI source to the speaker
Steps to re-program the EZ-USB™ SX3 HDMI 4K Capture Card
In EZ-USB™ SX3 HDMI 4K Capture Card Revision 01, there is no provision available to change the boot option using PMODE pins. To re-program the board, the device will need to boot as USB Bootloader Device.
To erase the on-board firmware and to get back the device to bootloader mode, open the command prompt in the folder where HID_Sample_App.exe is located and enter the reset command as shown below:
HID_Sample_App.exe -vid 0x04b4 -pid 0x00c2 -reset
Replace the vid and pid values with corresponding vendor ID and product ID of the connected device. Once it is successful, the “Erase and Fallback to Bootloader is successful” message is displayed as shown in the below screenshot.
Figure 10: Reset the existing firmware using HID_Sample_App.exe
Download the HID_Sample_App.exe file from the attachments. Once the board falls back to bootloader mode, follow the procedure from step 2 to program the device.
Additional learning resources:
Visit www.cypress.com/sx3 for additional resources like datasheet, and application note, configuration utility user guide.
Attachments with EZ-USB™ SX3 HDMI 4K Capture Card Solution Demo Kit:
  1. Schematic: SX3 HDMI 4K CAPTURE CARD Schematic.pdf
  2. BOM: SX3 HDMI 4K CAPTURE CARD _BOM.xls
  3. Board File: SX3 HDMI 4K CAPTURE CARD _layout.pdf
  4. EZ-USB SX3 Configuration File: sx3_hdmi_4K_capture_card.zip
  5. HID_Sample_App executable file: HID_Sample_App.zip
Version history
Revision #:
8 of 8
Last update:
‎Jul 26, 2021 05:16 AM
Updated by:
