Differences between CY62147G and CY62146G Asynchronous Memory Parts – KBA219723
Community-Team
50 questions asked 10 questions asked 5 questions asked
Translation - Japanese: 非同期メモリ部品のCY62147GとCY62146Gの違いについて – KBA219723 - Community Translated (JA)
Question:
What are the differences between CY62147G/CY62147E/CY62157E /CY62167E and CY62146G/ CY62136F/ CY62146E Asynchronous SRAMs?
Answer:
The devices differ from each other in terms of Byte-power down feature. For MPNs CY62XX7X, disabling BHE#/BLE# at the same time deselects the device and places it in standby mode. The device consumes ISB2 current. For MPNS CY62XX6X, disabling BHE#/BLE# has the same effect as disabling OE#. It only disables the I/Os but the device is still selected. This difference in byte-power down feature affects the duration taken by device to provide data output on BHE#/BLE# assertion (tDBE).
The tDBE (BLE#/BHE# LOW to data valid) parameter is different for both devices. For a comparison of the tDBE parameter, see the table below:
Parameter
Description
MPN
Period
tDBE
BLE / BHE LOW to data valid
CY62147G
CY62147E
CY62157E
CY62167E
CY62167EV
45ns
45ns
45ns
45ns
45ns
tDBE
CY62146G
CY62136F
CY62146E
22ns
22ns
22ns
See the figure below for the tDBE parameter.
Figure 1. Read Cycle (OE# Controlled)
See the device datasheets for more details timing parameters.
The two series of MPNs also differ in terms of truth table. In CY62147G/CY62147E/CY62157E/CY62167E, if BHE# and BLE# are high then the part is deselected or powered down. Whereas in CY62146G/CY62136F/CY62146E, only the I/Os are disabled provided the WE# is high and the chip is selected. So, the CY62146G/CY62136F/CY62146E part will consume more current than the other parts which will only consume standby current for this combination of BHE# and BLE#. See the datasheet for more details.
Truth Table – CY62146G/CY62146GE/CY62146GSL/CY62146GESL
CE1#
CE2
WE#
OE#
BHE#
BLE#
Inputs/Outputs
Mode
Power
H
X]
X
X
X
X
HI-Z
Deselect/Power-down
Standby (ISB)
X
L
X
X
X
X
HI-Z
Deselect/Power-down
Standby (ISB)
L
H
H
L
L
L
Data Out (I/O0–I/O15)
Read
Active (ICC)
L
H
H
L
H
L
Data Out (I/O0–I/O7);
HI-Z (I/O8–I/O15)
Read
Active (ICC)
L
H
H
L
L
H
HI-Z (I/O0–I/O7);
Data Out (I/O8–I/O15)
Read
Active (ICC)
L
H
H
H
X
X
HI-Z
Output disabled
Active (ICC)
L
H
H
X
H
H
HI-Z
Output disabled
Active (ICC)
L
H
L
X
L
L
Data In (I/O0–I/O15)
Write
Active (ICC)
L
H
L
X
H
L
Data In (I/O0–I/O7);
HI-Z (I/O8–I/O15)
Write
Active (ICC)
L
H
L
X
L
H
HI-Z (I/O0–I/O7);
Data In (I/O8–I/O15)
Write
Active (ICC)
Truth Table – CY62147G/CY62147GE
CE1#
CE2
WE#
OE#
BHE#
BLE#
Inputs/Outputs
Mode
Power
H
X
X
X
X
X
HI-Z
Deselect/Power-down
Standby (ISB)
X
L
X
X
X
X
HI-Z
Deselect/Power-down
Standby (ISB)
X
X
X
X
H
H
HI-Z
Deselect/Power-down
Standby (ISB)
L
H
H
L
L
L
Read
Active (ICC)
L
H
H
L
H
L
HI-Z (I/O8–I/O15)
Read
Active (ICC)
L
H
H
L
L
H
HI-Z (I/O0–I/O7);
Read
Active (ICC)
L
H
H
H
L
H
HI-Z
Output disabled
Active (ICC)
L
H
H
H
H
L
HI-Z
Output disabled
Active (ICC)
L
H
H
H
L
L
HI-Z
Output disabled
Active (ICC)
L
H
L
X
L
L
Write
Active (ICC)
L
H
L
X
H
L
HI-Z (I/O8–I/O15)
Write
Active (ICC)
L
H
L
X
L
H
HI-Z (I/O0–I/O7);
Write
Active (ICC)
Note: The ‘X’ (Don’t care) state for the chip enables refers to the logic state (either HIGH or LOW). Intermediate voltage levels on these pins are not permitted.
Contributors
