Difference between the 10bit ADC(1) and the 8bit ADC2
Infineon_Team
The ADC1 is a completely software controlled ADC fully available to the user application. While the ADC2 is a diagnostic ADC which supervises the voltages/ temperatures in the device. Programmable thresholds for each channel (voltage) provides a user adjustable generation of interrupts in case a measured voltage is crossing the thresholds.
