Difference between "One Shot with Single Trigger" and "One Shot with Multi Trigger" PWM Modes - KBA210683
04:06 AM
- Mark as Read
- Printer Friendly Page
Apr 07, 2016
04:06 AM
Version: **
Translation - Japanese: 「シングルトリガーのワンショット」と「マルチトリガーのワンショット」のPWMモードの違い - KBA210683 - Community Translated (JA)
Question:
What is the difference between the "One Shot with Single Trigger" and "One Shot with Multi Trigger" PWM Run modes?
Answer:
The "One Shot with Single Trigger" mode allows the PWM to run a single cycle with a single trigger. Subsequent triggers do not cause additional PWM cycles. However, in the "One Shot with Multi Trigger" mode, each trigger will cause a cycle.
Labels
Rate this article:
Contributors
This widget could not be displayed.Anonymous
