Difference between Sleep and Standby mode in Smart power high-side switches
Infineon_Team
Smart power high-side switches offer various functionalities which can be enabled / disabled and the different combinations of them are described as operation modes in the datasheet. Depending on the active functionalities it results in a certain current consumption of the device. For a better understanding when a functionality is active or not, smart high-side switches provide different operation modes.
Sleep Mode
One of the operation modes is the Sleep Mode which is implemented in every smart high-side switch. The sleep mode is entered when the device is supplied at the VS pin and all logic pins are set to “LOW’ and therefore the channel is in OFF-state. The current consumption is IVS(SLEEP).
Standby Mode
The Standby Mode, also called diagnosis in OFF mode, can be accessed from different modes, and only enables the diagnosis with DEN = “high” to read back certain information while the channel is switched off (IN = ‘low’). The current consumption in this mode is IGND(INACTIVE). In Table 1, an overview for the operation mode differences is given.
Table 1: Overview of differences for Sleep mode and Inactive mode (w/ diagnosis)
Operation mode
Supply voltage
IN
DEN
OUT
Current consumption
Sleep
VS
“low”
“low”
OFF
IVS(SLEEP)
Standby / diagnosis in OFF
VS
“low”
“high”
OFF
IGND(STBY) / IGND(OFF_D)
For lowest current consumption during OFF-state / parking mode it is recommended to use sleep mode of the device.
More information can be found here:  Smart Power Switches
Ask the Smart Power Switches Community
Infineon Developer Community is available 24x7 for you to connect and network with engineers across the globe. Get help from Infineon support engineers, and expert members to solve your design challenges anytime, from anywhere, in any topic, and in your preferred language.
Infineon Smart Power Switches & Gate Driver Tool Suite
To address the new needs in automotive power distribution, Infineon offers a wide variety of products and in addition this Smart Power Switches & Gate Driver Tool Suite to simplify the design in process.
Infineon Smart Power Switches & Gate Driver Tool Suite supports system architects and hardware designers from the idea to the realization.
