Difference between SVF and STAPL file formats
- Mark as Read
- Printer Friendly Page
Answer:
User can select file format SVF or STAPL depending on their requirment. The Serial Vector File (SVF) format is a widely adopted standard method of describing a set of high-level IEEE 1149.1 bus operations, consisting of scan operations and movements between different stable states on the IEEE 1149.1 state diagram. SVF is an alternative to STAPL, and is more suitable in certain applications, such as the embedded programming of devices. ISR 4.0 supports the creations of SVF files in order to provide compatibility with third party tools and users that have adopted this Dependent/Chain Independent modes when using the New Device Wizard. When the Composer is run, an ISR SVF ASCII text file is created to describe the operation and device selected.
Please be noted our entire Cypress CPLD product are Obsolete and not recommended for new design and development. For more information on CPLD product, please visit our webpage: http://www.cypress.com/go/cpld
- interface
This widget could not be displayed.Anonymous
