Demo software code for Lite SBC
Infineon_Team
The Microcontroller Library is a plugin inside the “Config Wizard for SBC”. It generates and provides a custom “C” code based on the individual user configuration that can be set in the Config Wizard. The code generated can be integrated easily inside a microcontroller software project in order to configure, startup and handle all functionalities of the SBC.
A description how to use the Microcontroller Library can be found on the web, here
