Debug SK-FM3-48PMC-USBSTICK on Windows 10 - KBA227529
ChaitanyaV_61
50 questions asked 25 likes received 25 sign-ins
Author: TakashiM_61            Version: **
Translation - Japanese: Windows 10でのSK-FM3-48PMC-USBSTICKのデバッグ - KBA227529 - Community Translated (JA)
SK-FM3-48PMC-USBSTICK has been obsoleted, and Windows 10 is not supported with this kit. Although the setup software of SK-FM3-48PMC-USBSTICK is installed in Windows 10, the following error is encountered:
Do the following to debug this kit within Windows 10 environment:
  • Remove the "FDTI JTAG + UART" part from SK-FM3-48PMC-USBSTICK.
  • Mount the 20-pin header on "X1" to connect JTAG directly.
Connect the debugger running on Windows 10 to this 20-pin header directly.
Contributors
