11:45 PM
- Mark as Read
- Printer Friendly Page
Jan 22, 2023
11:45 PM
DC Motor system IC TLE9560/1/2 - Is it possible to use the MOSFET driver to control a pure high-side MOSFET?
Yes, it is possible to control only a high-side (HS) MOSFET.
If the HS MOSFET controls an inductive load, a freewheeling diode is required to prevent the MOSFET from operating in avalanche at turn-off.
If the HS MOSFET is controlled in PWM, the MOSFET driver must be configured as passive freewheeling.
Labels
Rate this article:
