Could you give an application example for OptiMOS™ 6 40V?
Infineon_Team
Application example:
Synchronous rectification in server power supply.
OptiMOS™ 6 40V combines low RDS(on) with outstanding FOMs enabling optimized efficiency over the whole load range. Eliminating traditional trade-off between RDS(on) and switching losses. For more information, refer to the image provided.
