Connection problem: Die revision
03:55 AM
- Mark as Read
- Printer Friendly Page
Mar 26, 2011
03:55 AM
Question: I hooked up my POD to the CAT5 cable going to the ICE and when I try to 'Connect' this is the error I get. Silicon: 0004 Family: 0 Die: 0 Rev: AD
Answer:
This is telling you that the POD revision you are using is not compatible with the project that you are using while connecting.
You are using a different device POD than the device selected in the designer project.
Labels
- psoca 1
Rate this article:
Contributors
This widget could not be displayed.Anonymous
