Comparison of Cypress USB Type-C Hubs and Docks – KBA225754
- Mark as Read
- Printer Friendly Page
Author: RajathB_01 Version: **
Translation - Japanese: サイプレスUSB Type-Cハブとドックの比較 - KBA225754 - Community Translated (JA)
Question:
What are the differences between Cypress Type-C Hubs and Docks?
Answer:
- EZ-USB® HX3PD is the industry's first 7-port USB 3.1 Gen 2 Type-C Hub with USB Power Delivery 3.0 (PD 3.0), supporting five downstream USB 3.1 Gen 2 ports (three Type-C ports and two Type-A ports) and two downstream USB 2.0 ports. HX3PD is Cypress' most integrated USB hub, integrating a dual-port PD 3.0 controller (which provides PD 3.0 on one US and one DS Type-C port), a 7-port hub, and a Dock Management controller reducing Bill of Material (BOM) cost and solution footprint, making it ideal for USB Type-C docks, monitors, and standalone hubs.
- EZ-PD™ CCG4 Monitor/Dock Solution enables connectivity between a USB Type-C host system on the upstream port and multiple display and data devices on the downstream port. This solution has a USB Type-C receptacle on the upstream port which supports data, power, and display. On the downstream port, this solution supports one USB 3.0 Type-C (display, power, and data) port, three USB 3.0 Type-A ports, two USB 2.0 Type-A ports, one HDMI, and a Gigabit Ethernet port.
- EZ-USB® HX3C is Cypress’ USB 3.0 compliant Hub-controller with Type-C and USB Power Delivery 2.0 supporting three downstream USB 3.0 ports (one Type-C and two Type-A). As HX3C does not support the latest USB and Power Delivery standards (PD 3.0), it is not recommended for new designs.
EZ-USB® HX3C Monitor/Dock Solution enables connectivity between a USB Type-C connector of a host system on the upstream port and multiple display and data connectors on the downstream ports. This solution has a USB Type-C receptacle on the upstream port which supports data, power, and display. On the downstream port, the solution supports one USB Type-A port, one Gigabit Ethernet port, one Display port, and one USB Type-C port. This solution does not support the latest PD protocol rev 3.0, and hence is not recommended for new designs.
Table 1 and Table 2 compare the Hubs and the Dock solutions:
Table 1. Comparison of Type-C Hub Controllers
Hub Controller | EZ-USB HX3C | EZ-USB HX3PD |
Upstream Port Capability | Type-C with USB PD 2.0 | Type-C with USB PD 3.0 |
Number of DS ports | 3 | 7 |
Number of DS Type-C + PD ports | 1 (PD 2.0, USB 3.0) | 1 (PD 3.0, USB 3.1 Gen 2) |
Number of DS Type-C only ports | 0 | 2 x USB 3.1 Gen 2 |
Number of DS Type-A ports | 2 x USB 3.0 | 2 x USB 3.1 Gen2 + 2 x USB 2.0 |
USB data rate | 5 Gbps | 10 Gbps |
USB Power Delivery revision | 2.0 | 3.0 |
Battery Charging Protocols on DS Ports | BC1.2, Apple charging | BC1.2, Apple charging |
Firmware Update | Fixed firmware | HX3PD config utility over USB/PSoC® programmer over miniprog3 and SWD, Signed FW update possible |
Configuration | Fixed configuration | HX3PD config utility over USB |
Package | 121 BGA (10X10mm) | 192 BGA (12X12 mm) |
Table 2. Comparison of Type-C Docks
Dock Solution | EZ-USB HX3C Dock Solution | EZ-PD CCG4 Dock Solution |
Number of DS Type-C ports | 1 | 1 |
USB data rate | 5 Gbps | 5 Gbps |
Battery Charging protocols on DS ports | BC1.2, Apple charging | BC1.2, Apple charging |
Max power delivered on US Type-C | 45 W | 60 W, extendable up to 100 W* |
Max power delivered on DS Type-C | 15 W | 15 W, extendable up to 100 W* |
Firmware update and configuration | Fixed | Dock update and config tools over USB/PSoC programmer over miniprog3 and SWD, Signed FW update possible |
SDK support for customization | No | Yes (project and source available) |
*with minor hardware and firmware changes
