Communication Protocols Support in PSoC® 3, PSoC 4, and PSoC 5LP Bootloader Component - KBA84744
KishoreS_96
5 sign-ins 50 replies posted 25 replies posted
Version: *D
Translation - Japanese: PSoC®3、PSoC 4、およびPSoC 5LPブートローダーコンポーネントでの通信プロトコルのサポート - KBA84744 - Community Translated (JA)
Question:
What are the communication protocols supported by PSoC 3, PSoC 4, and PSoC 5LP Bootloader Component? What are the different bootloader hosts that can be used with PSoC 3, PSoC 4, and PSoC 5LP?
Answer:
The various communication protocols supported by the Bootloader Component (v1.50 in PSoC Creator4.0) are :
Communication
     Protocol
UDB or SCB
     implementation
App Note
Device
Bootloader Host Project provided
     with App Note
PSoC 3
PSoC 4
PSoC 5LP
PC
     Application
PSoC 3
     acting as
     a Host
PSoC 4
     acting as
     a Host
PSoC
     5LP
     acting as
     a Host
I2C
SCB
N/A
Yes
N/A
Yes
N/A
Yes
N/A
I2C
UDB
Yes
N/A
Yes
Yes
Yes1
No
Yes
SPI
UDB
Yes
Yes3
Yes
No
No1
No
Yes
UART
UDB
Yes
Yes
Yes
Yes
No1
No
Yes
USB(HID)
Fixed function
Yes
Yes4
Yes
Yes
N/A
N/A
N/A
For information on support for custom communication protocols, see the “Adding Bootloader Support” topic in the Component Author Guide (PSoC Creator > Help > Documentation > Component Author Guide) .
Note: PSoC Creator supports bootloading through SCB-based UART and SPI Components in PSoC 4.
1 PSoC 3 can be used as a bootloader host with modifications in the PSoC 5LP-based bootloader host project. However, because PSoC 3 has much lower flash size, a bootloadable project that works with PSoC 5LP may not work with PSoC 3 unless the flash space required by the bootloadable project can fit into PSoC 3’s flash. Therefore, it is recommended to use PSoC 5LP as the Bootloader host instead of PSoC 3.
2 The Application note also explains how to create a Windows-based bootloader host.
3 Application note is not available.
4 Only applicable for PSoC 4200L devices. Application note is not available.
Contributors
