Knowledge Base Articles
Common Anode configuration with PowerPSoC
Question: Is a common anode LED configuration possible with PowerPSoC?
Answer:
Yes, a common anode configuration while driving HB-LEDs is possible, which reduces the wire count for N channels from 2N to ‘N+1 ‘.A detailed explanation of this circuit method can be found in the Application note ‘AN52518: Driving LED Fixtures with Reduced Wire count ', available at the link below :
http://www.cypress.com/?rID=35363
Version history
Revision #:
1 of 1
Last update:
‎Mar 09, 2010 11:12 AM
Updated by:
Contributors
