Clear the Cache of ModusToolbox™
Charles_Lai
250 sign-ins 10 likes given 10 questions asked
ModusToolbox™ uses online content and creates its cache locally to speed up access.
The cache can be corrupted and you might see git-related errors.
Before further diagnosis, it's recommended you clear the cache of ModusToolbox™ first.
A) Clear the cache in user_home
  1. In Windows, go to the folder '%userprofile%\.modustoolbox'.
  2. Delete directories 'cache''git' and 'global'.
B) Clear the cache in your workspace
  1. Go to your workspace folder (the folder you save your projects and demos to).
  2. Delete the directory 'mtb_shared'. Don't forget to save your previous changes in that directory if you did.
  3. Perform "update" in Library Manager to your projects before building them.
When you finished A) and/or B) steps, restart ModusToolbox™ IDE to take effect.
