CapSense® Slider and RGB LED Example using the EZ-BLE™ Creator Module – KBA97020
Version: *B
Translation - Japanese: EZ-BLE™ モジュールを使用したCapSense スライダーおよびRGB LEDサンプル – KBA97020- Community Translated (JA)
Question:
Does Cypress provide a CapSense® slider and RGB LED example project for the EZ-BLE Creator Module (CYBLE-022001-00)?
Answer:
Yes, the project can be downloaded along with the user guide from the GitHub location: https://github.com/cypresssemiconductorco/EZ-BLE_PRoC_Module/tree/master/Example_projects
The project can be programmed on the EZ-BLE Creator Evaluation Board (CYBLE-022001-EVAL) plugged on to a BLE Pioneer Kit (CY8CKIT-042-BLE) baseboard.
This project is identical to the example project available as part of the BLE Pioneer Kit (CY8CKIT-042-BLE), the only difference being pin mapping changes. These changes are necessary to accommodate the difference in pin mapping between the CYBLE-022001-EVAL and the CY8CKIT-042-BLE baseboard (explained in the CYBLE-022001-EVAL quick start guide).
Downloading the Example Projects
The following steps should be followed to download the complete project and user guide:
  1. Go to the example project page on github.com and select “CapSense_Slider_and_RGB_LED.zip” as shown in the figure below.
     2.  Select “Raw” button, as shown in the following figure. All the project files and user guide will be downloaded as a .zip file.
Supported Kits and Software
Project
PSoC Creator
Version
Compiler
Development Kits
V3.1 SP2
V3.1 SP1 or lower
GCC
MDK
RVDS
CY8CKIT-042-BLE with CYBLE-022011-EVAL
CY8CKIT-042-BLE with PRoC BLE module (CY5671 or CY5674)
CY8CKIT-042_BLE with PSoC 4 BLE module (CY8CKIT-142 or CY8CKIT-141)
CapSense® Slider and RGB LED Example for
YES
NO
YES
YES
YES
YES
NO
NO
Contributors
