Can the CAN communication cutoff voltage in TLE9461ES be configured?
Infineon_Team
While using SBC TLE9461ES, if the supply voltage VCC1 falls below the VRT for more than the filter time tRF then the device will go into fail safe mode and the CAN communication will not function in SBC Normal mode.
The voltage at CAN is not configurable. What affects the CAN communication is the state in which the SBC is in. If it remains in Normal state, then there might be a sustained CAN operational even if the voltage drops for short period of time.
