Knowledge Base Articles
Can I use the ezusb.sys for the FX2?
Question: Can I use the ezusb.sys for the FX2?
Answer:
Yes . The driver ezusb.sys used to talk to the EZ-USB FX2 is the same as used for the EZ-USB and EZ-USB FX. However we recommend customer to use the latest USB driver CyUSB.sys for FX2 and FX2LP. You will find the driver CyUSB.sys in location C:\Program Files\Cypress\Cypress Suite USB 3.4.2\Driver once you have downloaded and installed SuiteUSB SDK 3.4.2
Version history
Revision #:
1 of 1
Last update:
‎Dec 19, 2008 12:00 AM
Updated by:
Contributors
