Knowledge Base Articles
Can I use S29GL256S NOR flash as primary booting memory for Xilinx Zynq-7000 SoC? - KBA234319
Chelladurai
Version: **
You cannot use S29GL256S as primary booting memory for Xilinx Zynq-7000 SoC because S29GL256S supports x16 data width and does not have an x8 option. The Xilinx Zynq-7000 SoC supports NOR flash with x8 data width only.
However, S29GL512T does have an x8/x16 option, so it can be used as the primary booting memory for Xilinx Zynq-7000 SoC.
Version history
Revision #:
2 of 2
Last update:
‎Nov 29, 2021 08:56 PM
Updated by:
