CY3207-ISSP Tester I/O Mating Connector
Question: Which is a mating connector with cable for TESTER I/O connector on right side of CY3207-ISSP programmer?
Answer:
The socket in the CY3207-ISSP device is from Phoenix Contact, Part#: 1881529
http://www.phoenixcon.com/
A potential mating connector for this part would be the Phoenix Contact Part# 1881406 also available from Digikey, Part#: 277-1438-ND
Contributors
