Building and adding the component in a project
pushekm_21
10 likes received 5 likes given First like received
Question: How to build a component once created? How to add a component in the project?
Answer:
Attached document discusses the following points:
1. How to add component in a project?
2. How the component should be build once it is created?
Contributors
