Build CCG4M Project Using CCG4 Project in SDK 3.0.1 and Later Versions – KBA219845
Community-Team
50 questions asked 10 questions asked 5 questions asked
Version: **
Translation - Japanese: SDK 3.0.1 またはそれ以降に含まれている CCG4 プロジェクトを使用して CCG4M プロジェクトをビルドする - KBA219845 - Community Translated (JA)
1. Question: Does EZ-PD SDK support example projects for CCG4M part numbers?
Answer: No
2. Question: How do I build CCG4M projects using EZ-PD SDK?
Answer: Use the CCG4 notebook project in EZ-PD SDK as a starting point and port it to the CCG4M part.
3. Question: How do I customize CCG4 firmware support to CCG4M based on SDK3.0.1 onwards?
Answer:
  1. Determine the CCG4 and CCG4M part number and pin assignment for firmware.
    CCG4M has two part numbers in the ordering information table in the CCG4M datasheet.
    Part Numbers
    To develop a CYPD4155-96BZXI project, use the CYPD4126-40LQXIT project from the EZ-PD SDK.
    To develop a CYPD4255-96BZXI project, use the CYPD4226-40LQXIT project from the EZ-PD SDK.
  2. In the firmware project, ensure that the I2C Master Component is enabled in TopDesign.cysch.
    Note: For Steps 3 and 4, you can download the datamux_ctrl.c file attached with this KBA and replace the datamux_ctrl.c file under the "solution" folder and ignore Steps 3 and 4.
  3. The USB 3.1 Gen 1/DP1.2 Mux that is internal to the CCG4M part uses the Slave Address 0x54. Change the I2C slave address assigned function in datamux_ctrl.c from 0x10 and 0x11 to 0x54.
    static const uint8_t mux_ps8740_address[NO_OF_TYPEC_PORTS] =
            0x10
    #if CCG_PD_DUALPORT_ENABLE
    #endif /* CCG_PD_DUALPORT_ENABLE */
    To:
           0x54
           0x54
  4. Delete/comment all defines/functions for external SS MUX PS8742B and replace the 'Parade' portion of the code to 'Pericom' in the datamux_ctrl.c file
  5. (Additional step for CYPD4155-96BZXI only) If the target part number is CYPD4155-96BZXI, a single Type-C port design, change the target part number to CYPD4126-40LQXIT using the PSoC Creator option as follows before going to Step 6.
    a. Right-click on the project name and use Device Selector to change the part number from CYPD4126-40LQXIT to CYPD4226- 40LQXIT.
    Figure 1. Changing the Target Device with Device Seletor
Figure 1
b. Open TopDesign.cysch, and locate the Bootloadable Component. Use the bootloader binary for the CYPD4226-40LQXIT part instead of the default one, which is for CYPD4126-40LQXIT.
Figure 2
Figure 2
   6. Ensure that pin assignment of each GPIOs on CYPD4155-96BZXI/ CYPD4255-96BZXI device matches the real hardware design. Closely associated with the schematic is the Design Wide Resources (DWR) view, which maps each schematic element to a pin, clock, or hardware block on the CCG4 device. Open the CYPD4126-40LQXI_notebook.cydwr file to see the DWR settings for the project.
Figure 3
As shown in Figure 3, the DWR view has several tabs, which configure aspects such as pin mapping, interrupt mapping, clock selection, and flash security. It is recommended that you restrict any changes to the DWR to the pin mapping view. Do not change the clock, interrupt, system, or flash configurations.
See the following table for GPIO port information versus ball location of CYPD4155-96BZXI/ CYPD4255-96BZXI
Name
CCG4M Ball Location
GPIO Port
VBUS_P_CTRL_P1
K3
P1_6
VBUS_C_CTRL_P1
K4
P1_7
VBUS_DISCHARGE_P1
K8
P2_5
VBUS_P_CTRL_P2
B4
P4_2
VBUS_C_CTRL_P2
B5
P4_1
VBUS_DISCHARGE_P2
B3
P4_3
VCONN_MON_P1/GPIO/VSEL_1_P1
L7
P2_4
SCL_3/VCONN_MON_P2/VSEL_1_P2
L10
P2_7
OVP_TRIP_P1/VSEL_2_P1
K5
P2_1
OVP_TRIP_P2
L8
P3_0
VBUS_MON_P1/GPIO
L4
P2_0
VBUS_MON_P2
B6
P4_0
HPD_P1/GPIO
K7
P2_3
HPD_P2/GPIO
E10
P3_4
GPIO/MUX_CTRL_3_P2
B9
P3_5
GPIO/MUX_CTRL_2_P2
B8
P3_6
GPIO/MUX_CTRL_1_P2
B7
P3_7
VSEL_2_P2/GPIO
H10
P3_1
I2C_SCL_SCB1_EC
L6
P0_1
I2C_SDA_SCB1_EC
K6
P0_0
I2C_INT_EC
L5
P2_2
I2C_SCL_SCB2_AR/GPIO
E2
P1_0
I2C_SDA_SCB2_AR/GPIO
D2
P1_3
I2C_INT_AR_P1
F2
P1_4
I2C_INT_AR_P2
G2
P1_5
SDA_3/GPIO
J10
P2_6
SCL_4
F10
P3_3
SDA_4
G10
P3_2
SWD_IO/AR_RST#
B2
P1_1
SWD_CLK/I2C_CFG_EC
C2
P1_2
7. Save all and rebuild the project.
Two verified examples of CCG4M are available with this KBA (ccg4m_example_projects.zip).
Contributors
