BTS5180:What is Sense saturation voltage?
Infineon_Team
The parameter itself should only give customers an idea about the range of the saturation voltage. It is meant to outline that the voltage at the I_S pin cannot be higher than the voltage at VS. Typically it is 2V below VS. The test conditions were used for the characteristic of the parameter and the parameter is not subject to production test.
