BTN99xx How to check it the slew rate level is set correctly?
Infineon_Team
The slew rate level can be read back in slew rate programming mode.
The two parameters are necessary for this:
  • Sense current for SR-level SR0 : IIS(SR0)
  • Current sense step between two SR-levels : IIS(SR_step)
