Advantages of using Chip Embedding over discrete package solutions – KBA238173
Infineon_Team
To meet higher requirements on power density, efficiency, reliability and cost reduction, Infineon proposes its Chip Embedding S-cells technology where the power discrete packages are no longer soldered on the PCB. Instead, they are embedded inside the PCB. This solution is called “Chip Embedding” technology.
The Chip Embedding technology offers several key advantages over discrete packages:
Category
Parameters
Advantages of Chip Embedding over
Discrete package solution
Power stage
On state resistance (RDS(ON))
Lower by 25–35%
Thermal resistance (Rth)
Lower by 45–50%
Thermal impedance (Zth)
Lower by 30–40%
Parasitic inductance (L)
Lower by 50–70%
Drain current (I_drain)
Higher by 55–60%
Power capability
Higher by 35–40%
Switching transients
Reduced significantly
Efficiency
Improved significantly
System interconnect
Loop resistance and inductance
Reduced
Compact design
Improved
Quality
Reliability
Improved
Thermal performance
Improved
Note: The values provided are based on a 48 V system and may vary in different test conditions.
