Accessing EZ-USB™ FX3 from multiple host applications– KBA234926
IFX_Publisher2
1000 replies posted First like given 750 replies posted
Version: **
EZ-USB™ FX3 can be opened or accessed from multiple host applications or multiple device handles can be opened for a single FX3 device.
The following figure shows an example of a FX3 device opened from two different host applications.
 Figure 1       Accessing EZ-USB™ FX3 from two host applications
Note: Infineon suggests not to read/write to the same endpoint from multiple host applications unless you can find a way to synchronize both the host applications and ensure that only one of it accesses the endpoint at a given time.
