AURIX™ MCU: Renaming a variable in AURIX™ Development Studio – KBA235953
Aug 09, 2022
10:21 PM
- Mark as Read
- Printer Friendly Page
Aug 09, 2022
10:21 PM
Community Translation: AURIX™ MCU: AURIX™ Development Studioでの変数の名前変更 – KBA235953
Version: **
AURIX™ Development Studio (ADS) inherits different Eclipse features. Using the Rename feature from Refactor, you can rename variables, methods, or other items in code, and make sure that the element used in every instance is updated correctly.
Do the following to access the Rename feature:
- Select the item that you want to rename and right-click it.
- Click Refactor and select Rename….
Note: You can also access it by pressing Alt + Shift + R keys
- Enter the new name and press Enter to rename as shown in the following figures.
Note: This KBA applies to the following series of AURIX™ MCUs:
- AURIX™ TC2xx series
- AURIX™ TC3xx series
Labels
Rate this article:
