AURIX™ MCU: ISO 26262, fault classification of a HW element and associated HW architecture metrics definition – KBA236342
Infineon_Team
Version: **
Fault classification (according to ISO26262-5:2018):
Failure modes are classified based on the potential to violate a safety goal.
Figure 1   Example of flow diagram for failure mode classification
Among these five failure rate categories, three have a negative contribution as they correspond to the portion of a failure mode of a hardware element that may violate a safety goal in the absence of a safety mechanism:
Table 1  Fault classification
Faults
Description
Single-point faults
Faults with potential to violate safety goal (PVSG) and they are not covered by any safety mechanism.
Residual fault
Portion of a random hardware fault that by itself leads to the violation of a safety goal and is not controlled by the safety mechanism.
Multiple-point fault, Latent
Multiple-point faults are not detected by any safety mechanism nor perceived by the driver.
The two metrics are as follows:
1.Single-point fault metric (SPFM)
According to ISO 26262-5:2018,
The SPFM requirement applies to ASIL B, C, and D of the safety goal. Use the calculation in Figure 2 to determine the single-point fault metric.
Figure 2   SPFM calculation
In other words,
  • (SPF + RF) FIT (Failure In Time) < 1% of the total faiure rate (ASIL D).
  • Quality Managed (QM) parts are excluded from the calculation.
  • FIT is calculated based on the area [mm^2] of all involved HW elements (see Figure 3).
Figure 3    Failure rate contribution to SPFM
Table 2  Possible source for the derivation of the target SPFM value
ASIL B
ASIL C
ASIL D
SPFM
≥90%
≥97%
≥99%
 2.
Latent-fault metric (LFM)
The LFM requirement applies to ASIL B, C, and D of the safety goal. Use the calculation in Figure 4 to determine the latent-fault metric:
Figure 4  LFM calculation
In other words,
  • MPF, L FIT < 10% (MPF, DP + Safe + MPF, L) [ASIL D].
  • QM parts are excluded from the calculation (see NOTE 1 in Figure 4).
  • FIT is calculated based on the area [mm^2] of all involved HW elements (see Figure 5).
Where,
  • MPF, L is Multiple point faults latent
Figure 5   Failure rate contribution to LFM
Table 3  Possible source for the derivation of the LFM target value
ASIL B
ASIL C
ASIL D
LFM
≥60%
≥80%
≥90%
