AURIX™ MCU: How to use an external precompiled library in an AURIX™ Development Studio - KBA235951
Aug 09, 2022
10:36 PM
- Mark as Read
- Printer Friendly Page
Aug 09, 2022
10:36 PM
Version: **
Follow these steps to use a precompiled library in an AURIX™ Development Studio project:
- Right-click on the project, select Properties -> AURIX™ Development Studio -> Build, and uncheck Auto-discover compiler include paths. It allows you to edit the include paths manually.
- Click on Active Project Properties from the toolbar and select TASKING C/C++ Compiler -> Include Paths.
- Add a new Include by clicking on the Add… button, select the folder containing the header file, and then click OK twice to return to the Project Properties.
- Select TASKING Linker -> Libraries.
- Select Add… -> Workspace and select the *.a file of the library.
- Click OK twice, then Apply and Close Now you can call the library methods and functions from within your project.
Note: This KBA applies to the following series of AURIX™ MCUs:
- AURIX™ TC2xx series
- AURIX™ TC3xx series
Labels
Rate this article:
