AURIX™ MCU: Generation of assembly files in AURIX™ Development Studio (ADS) – KBA235488
IFX_Publisher1
250 sign-ins First comment on KBA 250 replies posted
Community Translation: AURIX™ MCU : AURIX™ Development Studio (ADS)でのアセンブリファイルの生成 – KBA235488
Version: **
Follow these steps to generate the *.src files after a build in AURIX™ Development Studio:
  1. Create the makefile.targets file in the project root, with the following content:
    Note: The white space before the command “find” must be a TAB, do not use white space.
  1. Left-click the project, choose Properties, select C/C++ Build, and then select the Behavior tab.
  2. Add the target saveobjects to the Build (Incremental build) list of targets, as shown in the following screenshot.
    Figure 1
  3. Click Apply and Close. After a project build, the *.src files can be found in the Build folder with the extension *.src_bak (see Figure 2).
    Figure 2
Note:
This KBA applies to the following series of AURIX™ MCUs:
  • AURIX™ TC2xx series
  • AURIX™ TC3xx series
