AURIX™ MCU: Difference in retention time of program flash and data flash – KBA235019
IFX_Publisher1
250 sign-ins First comment on KBA 250 replies posted
Community Translation: AURIX™ MCU: プログラムフラッシュとデータフラッシュの保持期間の違い – KBA235019
Version: **
In AURIX™ MCUs, program flash has 20 years of data retention time while the data flash has 10 years. Because the program flash is written only a few times or maybe only once during production while data flash is written continuously in some applications. Both flash types use different technologies, so the retention time is also different.
Note that the 10-years data retention for data flash is valid only in the case of data written once and never updated again.
Table 1 Flash target parameters for TC29x
Parameter
Symbol
Values
Unit
Note / test condition
Min.
Typ.
Max.
Program flash retention time, sector
tRET CC
20
years
Max. 1000 erase/program cycles
Data flash endurance per EEPROMx sector
NE_EEP10 CC
125000
cycles
Max. data retention time 10 years
Data flash endurance per HSMx sector
NE_HSM CC
125000
cycles
Note: This KBA applies to the following series of AURIX™ MCUs:
  • AURIX™ TC2xx series
  • AURIX™ TC3xx series
